[mapguide-users] Cannot edit WMS configuration document in Maestro
Gunter Becker
gunter.becker at csogis.de
Thu Feb 26 14:39:55 PST 2015
Seems that the installation of MGOS3.0 causes the problem.
It turns out that only the WMS FeatureSource of an MGOS 3.0 server has the
before mentioned problem. When you open several connections to other MGOS
servers (in my case 2.4 and 2.6) in the same Maestro Window then the WMS
FeatureSources of the other servers also fail. Stand alone they are working
as expected.
I've also recognized that all entries in the "Select FDO Provider" box
exists twice when you have another connection to an older MGOS version aside
a MGOS 3.0 server connection in Maestro. For example:
"OSGeo FDO Provider for WMS" and "WMS Provider"
I've created a ticket in trac: 2541
<http://trac.osgeo.org/mapguide/ticket/2541>
Gunter
View this message in context: http://osgeo-org.1560.x6.nabble.com/Cannot-edit-WMS-configuration-document-in-Maestro-tp5190218p5190378.html
