[mapguide-users] MapGuide site administration page can't access after reboot
xjin2
xin.jin at pcni.org
Fri Jun 26 06:46:28 PDT 2015
I can not access the following URLs:
"*Configuring Apache HTTP Server*
This URL should display the standard Apache welcome page.
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?
OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://
This URL should return an XML document listing the contents of the MapGuide
repository. Enter
Administrator for the user id and admin for the password.
http://localhost:8008/mapguide/mapagent/index.html
This URL is a set of test forms for the map agent. The .html and .js files
should be removed from the
mapagent directory in a production environment.
*Configuring PHP*
The installation procedure installs PHP and supporting files. By default,
the files are installed in
/usr/local/mapguideopensource/webserverextensions/php
If you used the --prefix= Prefix option with the build_apt.sh command, the
Prefix /webserverextensions/php
The file php.ini-mapguide in the LinuxApt directory is used as a template
for creating php/lib/php.ini.
Paths in the template are changed to reflect the installation directories.
To check if PHP has been installed successfully, test the following URLs:
http://localhost:8008/mapguide/phpinfo.php
This URL should display the standard PHP info page. The string MapGuideApi
should appear midway
through the page.
http://localhost:8008/mapguide/mapadmin/login.php
This URL should display the MapGuide site administration page. Enter
and admin for the password."
Thank you Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-site-administration-page-can-t-access-after-reboot-tp5212750p5213121.html
