[mapguide-users] MapGuide site administration page can't access after reboot
Martin Morrison martin.morrison at edsi.com
Fri Jun 26 06:55:27 PDT 2015
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?
This should be changed to:
http://***YOUR_SERVER_NAME _OR_IP***:8008/mapguide/mapagent/mapagent.fcgi?
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of xjin2
Sent: Friday, June 26, 2015 9:46 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MapGuide site administration page can't access after reboot
I can not access the following URLs:
"*Configuring Apache HTTP Server*
This URL should display the standard Apache welcome page.
OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&RESOURCEID=Library://
This URL should return an XML document listing the contents of the MapGuide repository. Enter Administrator for the user id and admin for the password.
http://localhost:8008/mapguide/mapagent/index.html
This URL is a set of test forms for the map agent. The .html and .js files should be removed from the mapagent directory in a production environment.
*Configuring PHP*
The installation procedure installs PHP and supporting files. By default, the files are installed in /usr/local/mapguideopensource/webserverextensions/php
If you used the --prefix= Prefix option with the build_apt.sh command, the files are installed in Prefix /webserverextensions/php The file php.ini-mapguide in the LinuxApt directory is used as a template for creating php/lib/php.ini.
Paths in the template are changed to reflect the installation directories.
To check if PHP has been installed successfully, test the following URLs:
http://localhost:8008/mapguide/phpinfo.php
This URL should display the standard PHP info page. The string MapGuideApi should appear midway through the page.
http://localhost:8008/mapguide/mapadmin/login.php
This URL should display the MapGuide site administration page. Enter Administrator for the user id and admin for the password."
Thank you Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-site-administration-page-can-t-access-after-reboot-tp5212750p5213121.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
