[mapguide-users] MapGuide 2.5.2 Connexion Limit
Hans Milling
hm at geograf.dk
Tue Mar 3 04:44:43 PST 2015
Try to set the MaxConnections in both the ClientConnectionProperties and
SiteConnectionProperties to 100 and see if that helps.
The information about number of cores and how many maximum connections is
not correct. A connection can be left open to on the server without any
traffic, so unless you have a very old machine and have 100 users working on
the map all at once, there will not be any problem setting the maximum
connections to 100.
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-2-5-2-Connexion-Limit-tp5191129p5191170.html
