[mapguide-users] Commercial layers (Google Maps)
Jackie Ng
jumpinjackie at gmail.com
Fri May 8 06:59:11 PDT 2015
Re: 1)
Unless you are actually still on MapGuide Open Source 2.1, disregard
everything in that page. I don't have wiki edit privileges to fix/remove
that page.
Fusion and Maestro should make this easy from 2.2 onwards.
Re: 2)
Commercial and MapGuide layers are conceptually disconnected from each
other. There's no way to show a commercial layer in the legend, but you can
use the BaseMapSwitcher widget to turn off commercial layer (set the layer
option to NONE)
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Commercial-layers-Google-Maps-tp5204653p5204842.html
