[mapguide-users] mg-desktop and adding layers
VitecPer
per.bjorklund at vitec.se
Wed May 27 02:27:41 PDT 2015
Hello,
I am developing a small application which displays a map using mg-desktop.
Everything works great, but I want to show the current position of the
computer.
To do this I use the windows built-in location sensor to get the position.
To display the position, I want to add a layer to the map in run-time.
Much like this information
<http://addr.ris.ntpc.gov.tw/Geo4Oracle/help/devguide/modifying_maps_and_layers.html>
So far so good, the layer is added and the point is visible on the map.
But the problem is when I try to Zoom, the program crashes and throws a
System.Reflection.TargetInvocationException in System.dll.
(I can refresh the map without a crash!)
I don't know where the exception is coming from but I believe it has
something to do with the mglegend update.
Does anyone know what could be wrong or another way to add the GPS position
to the map?
View this message in context: http://osgeo-org.1560.x6.nabble.com/mg-desktop-and-adding-layers-tp5207736.html
