[mapguide-users] PostgreSQL SelectFeatures
Kori Maleski kori.maleski at gmail.com
Wed Nov 18 13:25:59 PST 2015
To get the Fusion buffer (or other widgets) to work with tables that contain
incompatible column data types (PostgreSQL  or any FDO FeatureSource for
that matter):
Modify Buffer.php so as to select compatible columns:
            $featureClassName = $selLayer->GetFeatureClassName();
            $filter = $sel->GenerateFilter($selLayer, $featureClassName);
            if($filter == "")
                continue;
            $query = new MgFeatureQueryOptions();
            $query->SetFilter($filter);
		    $classDef = $selLayer->GetClassDefinition();
			$geomPropName = $classDef->GetDefaultGeometryPropertyName();
			$propertyList = $classDef->GetProperties();
		    for($i=0; $i<$propertyList->GetCount(); $i++)
				$propertyDef = $propertyList->GetItem($i);
				$property = $propertyList->GetItem($i)->GetName();
				if(($property!=$geomPropName)&&($propertyDef->GetPropertyType()==100))
					$propertyType = $propertyList->GetItem($i)->GetDataType();
					switch ($propertyType) {
						case MgPropertyType::Boolean :
							$query->AddFeatureProperty($property);
							break;
						case MgPropertyType::Byte :
							break;
						case MgPropertyType::DateTime :
							break;
						case MgPropertyType::Single :
							break;
						case MgPropertyType::Double :
							break;
						case MgPropertyType::Int16 :
							break;
						case MgPropertyType::Int32 :
							break;
						case MgPropertyType::Int64 :
							break;
						case MgPropertyType::String :
							break;
				}else if($property==$geomPropName){
            $featureSource = new
MgResourceIdentifier($selLayer->GetFeatureSourceId());
            $features = $featureSrvc->SelectFeatures($featureSource,
$featureClassName, $query);
            if($features->ReadNext())
The same would have to be done in the Mapguide/Web/schemareport folder for
showclass.php as well as other instances where SelectFeatures is utilized.
View this message in context: http://osgeo-org.1560.x6.nabble.com/PostgreSQL-SelectFeatures-tp5236983p5237280.html
