[mapguide-users] blink a layer or a feature
Scott Hameister
scotth at mpowerinnovations.com
Fri Nov 20 06:31:13 PST 2015
Openlayers layers are different than mapguide layers..in openlayers I
believe mapguide is only two layers..the map and the selection image...then
each underlay map BING etc is another..you would have to ads your own layer
to openlayers. I don't recall what version Fusion is...you would search for
ol.Map or openlayers.Map to see the map creation and ol.Layer or
openlayers.layer for layer options.
On Nov 19, 2015 4:11 PM, "Liglio" <liglio at pobox.com> wrote:
> Hi,
> I looked at Fusion code and I saw that all layers are added from the
> Library
> Map. Can I point to a layer object, already included in the map, using an
> Openlayer object and control the visibility, or I have to remove that layer
> from the map (using Studio) and manually (using code) add the layer to
> OpenLayers to have control of the layer ?
> Thanks
> http://osgeo-org.1560.x6.nabble.com/blink-a-layer-or-a-feature-tp5236968p5237526.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20151120/6a0ab0e2/attachment.html>
