[mapguide-users] mgcooker : use more cpu resource ?
Jackie Ng
jumpinjackie at gmail.com
Fri Oct 2 21:29:44 PDT 2015
There's a thread count setting in the MgCooker UI (that should also be saved
if you're generating an executable script). Does that not multi-thread the
tile generation process?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/mgcooker-use-more-cpu-resource-tp5227688p5227691.html
