[mapguide-users] SQL Server Spatial View Selection Issue
RenoSun renolionheart at gmail.com
Wed Oct 7 11:44:04 PDT 2015
Hi Jakie,
Thank you for your reply, and I modified the config.xml that export from one
of my SQL Server DB.
I only left three SQL Server Spatial View in the config.xml, and I paste the
content of the config.xml back to AIMS SQL Server feature source
configuration document by using Maestro, and it works!
However, if I use my fusion with Anonymous account (not Admin), the layers
won't show up on my browsers. It only allowed me to preview by using Maestro
or Infrastructure Studio. However, I am using different account for my
fusion login, it works perfectly now. I can select all my SQL Server Spatial
views as long as I added them to the feature source configuration document
For another database that I have, do you know how can I export the data
store configuration to xml only including a few specific the SQL Server
Spatial views?
Thanks!!! a LOT!
View this message in context: http://osgeo-org.1560.x6.nabble.com/SQL-Server-Spatial-View-Selection-Issue-tp5228068p5228575.html
