[mapguide-users] SQL Server Spatial View Selection Issue
Jackie Ng jumpinjackie at gmail.com
Thu Oct 8 02:08:35 PDT 2015
Note that configuration documents are also a nice attack surface reduction
and performance improvement measure as you're telling MapGuide *what* your
data store structure is like instead of letting the FDO provider find out
for itself.
If you describe the schema of a configured feature source, it isn't going to
return all 1000 tables in your database, it's only going to return the
number of tables/featureclasses you defined in the configuration document.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/SQL-Server-Spatial-View-Selection-Issue-tp5228068p5228682.html
