[mapguide-users] What Java version is needed for Mapguide 3.0?
Flipper
scotth at mpowerinnovations.com
Tue Oct 27 15:49:41 PDT 2015
Jackie, Are their some newer dependencies than what I copied? I'm confused
as to why this has worked for so long and now cold fusion can't work with
them?
On Oct 27, 2015 5:55 PM, "Jackie Ng [via OSGeo.org]" <
ml-node+s1560n5232944h51 at n6.nabble.com> wrote:
> All I can say is we've always used a Java 6 SDK for the Java components in
> MapGuide.
> - Jackie
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/What-Java-version-is-needed-for-Mapguide-3-0-tp5232882p5232944.html
> To unsubscribe from What Java version is needed for Mapguide 3.0?, click
> here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5232882&code=c2NvdHRoQG1wb3dlcmlubm92YXRpb25zLmNvbXw1MjMyODgyfDMyMzM0MDY4Mg==>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/What-Java-version-is-needed-for-Mapguide-3-0-tp5232882p5232945.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20151027/a71ec014/attachment.html>
