[mapguide-users] locale=<your ISO 639-1 language code>
Jackie Ng jumpinjackie at gmail.com
Thu Sep 17 16:44:43 PDT 2015
Whatever locale=$LANG you pass to the Fusion template, it will use the same
$LANG value when sending requests to the mapagent.
If locale=$LANG is included in requests to the mapagent, then when any
errors occur on the Server or Web Tier, it will be looking for the localized
error message in a file named mapguide_$LANG.res that should be in the same
place where mapguide_en.res (the default string bundle) is located in.
If no such file exists, I think error messages from the Server or Web Tier
would fall back to english.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/locale-your-ISO-639-1-language-code-tp5224164p5224720.html
