[mapguide-users] Custom widget in Task pane
madhur chanana
madhurchanana92 at gmail.com
Thu Aug 4 00:02:35 PDT 2016
I want to create a custom widget in Fusion that opens in Task pane on
clicking. The widget is to implement Google Places search on the map. I
found a result on the mailing list that involves changing the Taskpane.html
file. But that opens in the task pane instants rather than as a widget.
The code for the Taskpane.html is:
<!DOCTYPE html>
<html>
<head>
<script type="text/javascript" src="
https://maps.googleapis.com/maps/api/js?sensor=false"></script>
src="proj4js-1.1.0/lib/proj4js-compressed.js"></script>
<SCRIPT LANGUAGE="JavaScript">
//Proj4js.defs["EPSG:4326"]="+proj=longlat +ellps=WGS84 +datum=WGS84
+no_defs"
var source = new Proj4js.Proj('EPSG:4326');
Proj4js.defs["EPSG:3857"]="+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs"
var dest = new Proj4js.Proj('EPSG:3857');
var geocoder = new google.maps.Geocoder();
function extraire_xy_geocode()
var address =
window.document.getElementById("adresse_google_texte").value;
if (address == "")
alert("Erreur : Veuillez fournir une adresse dans la case à cette
fin!");
else
geocoder.geocode
( {'address': address}, function(results, status)
if ((status == google.maps.GeocoderStatus.OK) && (results.length
== 1))
var map = parent.Fusion.getWidgetById('Map');
var coordll = results[0].geometry.location;
var lat = coordll.lat();
var lng = coordll.lng();
var p = new Proj4js.Point(lng,lat);
Proj4js.transform(source, dest, p);
var pt = new parent.OpenLayers.LonLat(p.x,p.y);
if
(window.document.forms["origine"].elements["radio_ech_larg"].item(0).checked
== true)
// selon échelle (scale of map)
map.oMapOL.setCenter(pt,map.oMapOL.getZoom(),false,false);
map.oMapOL.zoomToScale(parseInt(window.document.forms["origine"].elements["txt_echelle"].value),false);
else
// selon largeur (width of map)
var largeur =
parseInt(window.document.forms["origine"].elements["txt_echelle"].value);
var centreXY = map.oMapOL.getCenter();
var fenetre = new parent.OpenLayers.Bounds (centreXY.lon - (largeur /
2.0), centreXY.lat - (largeur / 2.0), centreXY.lon + (largeur / 2.0),
centreXY.lat + (largeur / 2.0));
map.oMapOL.zoomToExtent(fenetre,false);
var olMap = map.oMapOL;
var oldmarkers = olMap.getLayersByName ( "Markers" );
if (oldmarkers[0] != undefined)
{olMap.removeLayer(olMap.getLayer(oldmarkers[0].id))};
var markers = new parent.OpenLayers.Layer.Markers( "Markers" );
olMap.addLayer(markers);
var size = new parent.OpenLayers.Size(21,25);
var offset = new parent.OpenLayers.Pixel(-(size.w/2), -size.h);
var icon = new parent.OpenLayers.Icon('
http://www.openlayers.org/dev/img/marker.png', size, offset);
markers.addMarker(new parent.OpenLayers.Marker(pt,icon));
markers.addMarker(new parent.OpenLayers.Marker(pt,icon.clone()));
else
if (results.length > 1)
alert("Le géocodage a échoué, car plus d'un résultat.");
else
alert("Le géocodage a échoué pour la raison suivante : " + status);
</SCRIPT>
<style type="text/css">
@import url(TaskPane.css);
</style>
</head>
<BODY >
<P>
<STRONG><EM>Zoom centre:</EM></STRONG>
</P>
<P>
<FORM name='googleform' action="javascript:extraire_xy_geocode()" >
<INPUT type=submit value="Adresse Google" style="line-height: 22px; width:
110px " />
<input autocomplete="on" id="adresse_google_texte"
name="adresse_google_texte" type="text" style="WIDTH: 150px; HEIGHT: 22px;
TEXT-ALIGN: left" />
</FORM>
</P>
<FORM autocomplete="on" name='origine' style="BORDER-TOP-WIDTH: 1px;
BORDER-LEFT-WIDTH: 1px; BORDER-LEFT-COLOR: red; BORDER-BOTTOM-WIDTH: 1px;
BORDER-BOTTOM-COLOR: red; COLOR: red; BORDER-TOP-COLOR: red;
BORDER-RIGHT-WIDTH: 1px; BORDER-RIGHT-COLOR: red" >
<P>
<INPUT type=radio value="echelle" name="radio_ech_larg" CHECKED>
Echelle</INPUT>
<br>
<INPUT type=radio value="largeur" name="radio_ech_larg"> Largeur</INPUT>
<br>
<INPUT id=txt_echelle style="HEIGHT: 22px; TEXT-ALIGN: right" size=5
value=2000 name=echelle title=Echelle vrml=""></INPUT>
</P>
</FORM>
</P>
</BODY>
</html>
How can i convert this to a widget that i can attach to a toolbar an work
with only when needed ?
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20160804/74e464dc/attachment.html>
