[mapguide-users] Mapguide 3.0 Postgre view problem
sebafr sebafr at gmail.com
Tue Dec 6 09:11:22 PST 2016
You should update the layer (recreate if need) and mapguide (if you need to
stop and restart the service)
Try and see if it works:
1) Try to create another view only from the main table (no join or
function), remember to put the primary key in the view
2) Create a new layer for this new view
3) test the mapguide selection
4) If it works, please create a new layer for the view with the function and
test again, remembering to include the primary key.
The use of functions is not detected by mapguide as a join, so it should
work!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-3-0-Postgre-view-problem-tp5298765p5298852.html
