[mapguide-users] invalid geomatry in oracle spatial
Emese Szász
szvatopluk at gmail.com
Fri Dec 23 03:06:57 PST 2016
Thanks, but all the records are in 2D, only the following gtype-s are
in the table: 2001, 2002, 2003
2016-12-23 11:51 GMT+01:00 Hans Milling <hm at geograf.dk>:
> Try to run sdo_cs.make_2d(...) on the geometry column or include this in
> the
> select you use when extracting data. the FDO provider or SDF file does not
> support 3d coordinates, and some systems store the coordinates as 3d
> coordinates, even though the height value is always 0. 3D coordinates will
> not fail the validate_geometry.
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/invalid-geomatry-in-oracle-spatial-tp5301161p5301170.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Szász Emese
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20161223/f25d2332/attachment.html>
