[mapguide-users] mg-Desktop crash when started without network	connection
    VitecPer
    per.bjorklund at vitec.se
    Wed Jan 13 00:31:21 PST 2016
Hello,
I have developed a program using Mapguide Desktop.
When the computer is plugged in to the network it works as intended, but
when the computer is booted without a network connection it crashes when
loading the map.
I have also tested the mgp with the MapViewerTest.exe but I am getting the
same result.
The map only uses managed SHP files so it shouldn't try to connect to the
network for information.
The error I am getting is:
OSGEo.Mapguide.MgFileIoException: A file IO exception occurred:
Repositores/Library/DataFiles/NetOnWeb/Data/SP_JOB.FeatureSource/SP_JOB.DBF
at MgDResourceService::SetResourceData() Line 821
   file
C:\working\build_area\mapguide\2.6.1\x64\mgdev\desktop\mgdesktop\services\ResourceService.cpp
at MgByteSink.ToFile() line 218
   file
C:\working\build_area\mapguide\2.6.1\x64\mgdev\common\foundation\Data\ByteSink.cpp
Does anyone have any idea what the problem is?
/Per
View this message in context: http://osgeo-org.1560.x6.nabble.com/mg-Desktop-crash-when-started-without-network-connection-tp5244894.html
