[mapguide-users] mg-Desktop crash when started without network connection
VitecPer per.bjorklund at vitec.se
Wed Jan 13 05:42:04 PST 2016
It crashes but not on the same file.
This is what Process Monitor logs when the exception occures.
Date & Time:	2016-01-13 14:16:20
Event Class:	File System
Operation:	CreateFile
Result:	DELETE PENDING
Path:	C:\Program Files\Vitec
Energy\Satellite\Repositories\Library\DataFiles\NetOnWeb\Data\SP_JORDTAG_HOGS.FeatureSource\SP_JORDTAG_HOGS.dbf
TID:	436
Duration:	0.0001540
Desired Access:	Generic Write, Read Attributes
Disposition:	OverwriteIf
Options:	Synchronous IO Non-Alert, Non-Directory File
Attributes:	n/a
ShareMode:	Read, Write, Delete
AllocationSize:	0
The file is also accessed some miliseconds before to preform the operation
"SetDispositionInformationFile".
Does this occur because the computer is too slow?
View this message in context: http://osgeo-org.1560.x6.nabble.com/mg-Desktop-crash-when-started-without-network-connection-tp5244894p5244995.html
