[mapguide-users] mg-Desktop crash when started without network connection
VitecPer
per.bjorklund at vitec.se
Mon Jan 18 04:58:41 PST 2016
I found the problem!
Apparently Windows Search Service has a task called SearchIndexer.exe.
This process handles the indexing of your files for the search engine.
If you remove a file the SearchIndexer removes it from the index. And vice
versa.
On this ( somewhat old) computer this caused a race condition between the
removing and adding of new shape-files and the indexing.
After I stopped the Windows Search service the program worked as intended.
Thanks for the tip Jackie.
/Per
View this message in context: http://osgeo-org.1560.x6.nabble.com/mg-Desktop-crash-when-started-without-network-connection-tp5244894p5245875.html
