[mapguide-users] Google Layers Not Showing - Fix to Open Layers
sebafr sebafr at gmail.com
Tue Jun 7 06:39:45 PDT 2016
I have problem with google layers on mapguide.
The big problem was everthing look fine when use SATELLITE option
(G_SATELLITE_MAP), but if use another option (G_HYBRID_MAP or G_PHYSICAL_MAP
etc) the map hangs and show nothing as base layer.
This post solved this. Thanks a lot
View this message in context: http://osgeo-org.1560.x6.nabble.com/Google-Layers-Not-Showing-Fix-to-Open-Layers-tp5268375p5270395.html
