[mapguide-users] Mapguide OS WMS service is not showing any geometry
Hans Milling
hm at geograf.dk
Tue Jun 28 02:01:22 PDT 2016
I suspect the "localhost". This is only valid if you run local on the server.
If you use the WMS from outside you have to specify the outside IP address
or DNS.
>From MapGuide Maestro go to Tools -> Site Administrator and checxk the WMS
settings. Replace localhost:8008 with the correct outside ip or name for the
server and also the correct port (in my setups it is always 80).
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-OS-WMS-service-is-not-showing-any-geometry-tp5273564p5273715.html
