[mapguide-users] MgFDOexception
madhur chanana
madhurchanana92 at gmail.com
Wed May 18 21:54:08 PDT 2016
I am Getting the following error while uploading a Shapefile to Mapguide
maestro using SHP Provider:
System.Exception: The remote server returned an error: (559)
MgFdoException.:
An exception occurred in FDO component.
Error occurred in Feature Source
(Library://SEAEQ/Data/Myanmar.FeatureSource): An exception occurred in FDO
component.
The directory 'C:\Program
Files\OSGeo\MapGuide\Server\Repositories\Library\DataFiles\a953b206-1d7c-11e6-8000-3cd92b6c2c12\Myanmar.shp'
does not exist.
- MgFdoConnectionManager.Open() line 333 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\common\manager\FdoConnectionManager.cpp
- MgFdoConnectionManager.CacheFdoConnection() line 1097 file
- MgFdoConnectionManager.Open() line 1089 file
(Cause: , Root Cause: )
- MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpDescribeSchemaAsXml.Execute() line 110 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
- MgServerFeatureService.DescribeSchemaAsXml() line 381 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerFeatureService.cpp
- MgServerDescribeSchema.DescribeSchemaAsXml() line 643 file
c:\working\build_area\mapguide\3.0.0\x64\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
- MgServerDescribeSchema.DescribeSchema() line 579 file
- MgServerDescribeSchema.DescribeFdoSchema() line 217 file
- MgFdoConnectionManager.Open() line 366 file
---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
at System.Net.HttpWebRequest.GetResponse()
at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead(String req)
in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\OSGeo.MapGuide.MaestroAPI.Http\HttpServerConnection.cs:line
1371
--- End of inner exception stack trace ---
1387
at
OSGeo.MapGuide.MaestroAPI.HttpServerConnection.DescribeFeatureSourceInternal(String
resourceID) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
773
at
OSGeo.MapGuide.MaestroAPI.PlatformConnectionBase.DescribeFeatureSource(String
trunk\workspace\OSGeo.MapGuide.MaestroAPI\PlatformConnectionBase.cs:line
1519
at
OSGeo.MapGuide.MaestroAPI.Commands.ExecuteLoadProcedure.ExecuteShpLoadProcedure(LengthyOperationProgressCallBack
cb, IShpLoadProcedure shpl, Boolean& firstExecution) in
trunk\workspace\OSGeo.MapGuide.MaestroAPI\Commands\ExecuteLoadProcedure.cs:line
408
at
OSGeo.MapGuide.MaestroAPI.Commands.ExecuteLoadProcedure.Execute(ILoadProcedure
proc, LengthyOperationProgressCallBack callback) in
177
at
OSGeo.MapGuide.MaestroAPI.PlatformConnectionBase.ExecuteLoadProcedure(ILoadProcedure
loadProc, LengthyOperationProgressCallBack callback, Boolean
ignoreUnsupported) in c:\working\JenkinsCI\home\slave_win\jobs\Maestro
trunk\workspace\OSGeo.MapGuide.MaestroAPI\PlatformConnectionhBase.cs:line
2344
at
Maestro.Editors.LoadProcedure.LoadProcedureEditorCtrl.ExecuteLoadProcedure(BackgroundWorker
worker, DoWorkEventArgs e, Object[] args) in
trunk\workspace\Maestro.Editors\LoadProcedure\LoadProcedureEditorCtrl.cs:line
146
at Maestro.Shared.UI.ProgressDialog.BackgroundWorker_DoWork(Object
sender, DoWorkEventArgs e) in
trunk\workspace\Maestro.Shared.UI\ProgressDialog.cs:line 112
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object
argument)
Help me resolve the issue. The file is working while uploading using a
different machine.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20160519/15236def/attachment.html>
