[mapguide-users] QueryMapFeatures throws OSGeo.MapGuide.MgDbException
Hans Milling
hm at geograf.dk
Mon Oct 17 07:05:15 PDT 2016
Hi
I am using MaestroAPI 6 and MapGuide 3.1. I am trying to query a map using
the QueryMapFeatures function. I create the runtime map using the CreateMap
function and later query the map.
I call the query this way:
The last lines fails with:
Exception thrown: 'OSGeo.MapGuide.MgDbException' in
OSGeo.MapGuide.MapGuideCommon.dll
The MapGuide server error.log says:
Error: An exception occurred in DB component.
Db::put: DB_LOG_BUFFER_FULL: In-memory log buffer is full
If I validate the map in MapGuide Maestro I get no errors. How can I
troubleshoot what is causing this error?
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/QueryMapFeatures-throws-OSGeo-MapGuide-MgDbException-tp5291061.html
