[mapguide-users] MapGuide Load Balancing PDF document
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Sat Oct 22 15:27:49 PDT 2016
You can find everything in Mapguide Rfc3:
https://trac.osgeo.org/mapguide/wiki/MapGuideRfc3
<https://trac.osgeo.org/mapguide/wiki/MapGuideRfc3>
I have try this, but it is much slower than puting multiple MG nodes (web
and server) behind some other load ballancer (e.g. HaProxy). Mapguide
Session affinity can be accomplish with sticky setting on HaProxy config.
In both case you have to sync Repository.
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Load-Balancing-PDF-document-tp5290237p5292107.html
