[mapguide-users] Difference to QueryMapFeatures when using LocalNative and HttpConnection
Jackie Ng
jumpinjackie at gmail.com
Tue Oct 18 04:07:51 PDT 2016
Oops, I totally read your question wrong.
I just had a look at the LocalNative provider code. It's implementation is
completely wrong. It should be housing the FeatureSet XML inside a
FeatureInformation root XML element, and use the MgFeatureInformation to
write out the sibling Hyperlink and Tooltip XML elements. Definitely a bug.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Difference-to-QueryMapFeatures-when-using-LocalNative-and-HttpConnection-tp5291219p5291240.html
