[mapguide-users] Bug: CreateRuntimeMap returns scalerange with „Null“ when using Raster or WMS-layers in Map
Matze schramm at kom21.de
Wed Oct 19 05:52:13 PDT 2016
Bug noticed: CreateRuntimeMap returns  scalerange  with „Null“ when using
Raster or WMS-layers in Map.  Vectorlayer causes no Problems.
In example the JSON returnvalue and the related LayerDefinition
/*TIF-Gridlayer:*/
            "FeatureSource": [{
                "ClassName": ["default:default"],
                "Geometry": ["Raster"],
                "ResourceId":
["Library://MobileViewer/Rasterdaten/TIF.FeatureSource"]
            "LayerDefinition":
["Library://MobileViewer/Rasterdaten/TIF.LayerDefinition"],
            "LegendLabel": ["TIF"],
            "Name": ["TIF"],
            "ObjectId": ["305a0c88-95d6-11e6-8002-0050569cbc24"],
            "ParentId": ["3057aaf6-95d6-11e6-8003-0050569cbc24"],
            *"ScaleRange": null,
/*TIF.LayerDefinition.xml:*/
<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="LayerDefinition-2.4.0.xsd" version="2.4.0">
  *<GridLayerDefinition>
<ResourceId>Library://MobileViewer/Rasterdaten/TIF.FeatureSource</ResourceId>
    <Watermarks />
    <FeatureName>default:default</FeatureName>
    <Geometry>Raster</Geometry>
    <GridScaleRange>
      <MinScale>10000</MinScale>
      <MaxScale>500000</MaxScale>
      <ColorStyle>
        <ColorRule>
          <LegendLabel>
          </LegendLabel>
          <Color>
            <ExplicitColor>000000</ExplicitColor>
          </Color>
        </ColorRule>
        <ColorRule>
          <LegendLabel>
          </LegendLabel>
          <Color>
            <ExplicitColor>FFFFFF</ExplicitColor>
          </Color>
        </ColorRule>
      </ColorStyle>
      <RebuildFactor>1</RebuildFactor>
    </GridScaleRange>
  </GridLayerDefinition>
</LayerDefinition>
*Flurstuecke-Vectorlayer:*/
        "Layer": [{
            "ActuallyVisible": ["true"],
            "DisplayInLegend": ["true"],
            "ExpandInLegend": ["true"],
            "FeatureSource": [{
                "ClassName": ["Default:AX_Flurstueck"],
                "Geometry": ["Geometry"],
                "ResourceId":
["Library://MobileViewer/Flurkarte/Daten/AX_Flurstuecke.FeatureSource"]
            "LayerDefinition":
["Library://MobileViewer/Flurkarte/Layer/Flurstuecke.LayerDefinition"],
            "LegendLabel": ["Flurstuecke"],
            "Name": ["Flurstuecke"],
            "ObjectId": ["305a0c88-95d6-11e6-8000-0050569cbc24"],
            "ParentId": ["3057aaf6-95d6-11e6-8001-0050569cbc24"],
            *"ScaleRange": [{
                "FeatureStyle": [{
                    "Rule": [{
                        "Filter": null,
                        "Icon":
["iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAABHNCSVQICAgIfAhkiAAAADpJREFUOI1jYGBg2MrAwPCfTLyVEcogG7AgsRlJ1PufgYGBgYkS20cNGDVg8BhAcWZiYmBg2EaB/m0AZkoT5bViUtAAAAAASUVORK5CYII="],
                        "LegendLabel": null
                    "Type": ["3"]
                "MaxScale": ["1000000000000"],
                "MinScale": ["0"]
*            "Selectable": ["true"],
            "Type": ["1"],
            "Visible": ["true"]
*Flurstuecke.LayerDefinition.xml:*/
  *<VectorLayerDefinition>
<ResourceId>Library://MobileViewer/Flurkarte/Daten/AX_Flurstuecke.FeatureSource</ResourceId>
    <Watermarks />
    <FeatureName>Default:AX_Flurstueck</FeatureName>
    <FeatureNameType>FeatureClass</FeatureNameType>
    <PropertyMapping>
      <Name>GISID</Name>
      <Value>GISID</Value>
    </PropertyMapping>
    <PropertyMapping>
      <Name>AMTLICHEFL</Name>
      <Value>AMTLICHEFL</Value>
    </PropertyMapping>
    <Geometry>Geometry</Geometry>
    <VectorScaleRange>
      <AreaTypeStyle>
        <AreaRule>
          <LegendLabel>
          </LegendLabel>
          <AreaSymbolization2D>
            <Fill>
              <FillPattern>Solid</FillPattern>
              <ForegroundColor>00FFFFFF</ForegroundColor>
              <BackgroundColor>ffffffff</BackgroundColor>
            </Fill>
            <Stroke>
              <LineStyle>Solid</LineStyle>
              <Thickness>1</Thickness>
              <Color>ff000000</Color>
              <Unit>Points</Unit>
              <SizeContext>MappingUnits</SizeContext>
            </Stroke>
          </AreaSymbolization2D>
        </AreaRule>
      </AreaTypeStyle>
    </VectorScaleRange>
  </VectorLayerDefinition>
</LayerDefinition>
MapGuide Server (Version 3.0.0.8701)
MapGuide Viewer (Version 3.0.0.8701)
Windows Server 2012 R2 Standard 64 Bit
Ajax Viewer with PHP
Tested with Internet Explorer 11 and  Chrome Version 51.0.2704.103 m
Matze
View this message in context: http://osgeo-org.1560.x6.nabble.com/Bug-CreateRuntimeMap-returns-scalerange-with-Null-when-using-Raster-or-WMS-layers-in-Map-tp5291469.html
