[mapguide-users] Problems getting LocalNative and MapGuide 3.1 to work with MaestroAPI 6
Hans Milling
hm at geograf.dk
Tue Sep 27 02:55:45 PDT 2016
Hi MapGuide Users
I compiled OSGeo.MapGuide.MaestroAPI.Native-3.1.0.dll using the
ProviderTemplate.exe file provided with the MaestroSDK.
However when I copy the file to the Test directory and run the test (I have
modified the ConnectionProviders.xml) I get the following error:
Errors and Failures:
1) SetUp Error : MaestroAPITests.TestBootstrap
SetUp : System.IO.FileLoadException : Could not load file or assembly
'OSGeo.MapGuide.MaestroAPI, Version=6.0.0.8909, Culture=neutral,
PublicKeyToken=f526c48929fda856' or one of its dependencies. The located
assembly's manifest definition does not match the assembly reference.
(Exception from HRESULT: 0x80131040)
at MaestroAPITests.TestBootstrap.Setup()
I have checked the OSGeo.MapGuide.MaestroAPI.dll file (right
click->properties->details) and the version is 6.0.0 and no build number is
visible. How can I fix this? Is the LocalNative dll built with a different
version or is it the test app that is using a different version or what is
the reason for this error?
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-getting-LocalNative-and-MapGuide-3-1-to-work-with-MaestroAPI-6-tp5287977.html
