[mapguide-users] Problems getting LocalNative and MapGuide 3.1 to work with MaestroAPI 6
Jackie Ng jumpinjackie at gmail.com
Tue Sep 27 06:02:25 PDT 2016
I built a 3.1 connection provider with ProviderTemplate.exe and
 1. Copied the provider dll and the MapGuide 3.1 dlls to the test output
directory
 2. Modified the ConnectionProviders.xml file to register this provider
 3. Modify TestMaestroAPI.xml to deactivate the Local provider tests and
activate the LocalNative provider tests
I was able to run the tests without errors.
So this suggests that it's picking up dlls from somewhere else. Are any
MapGuide/Maestro dlls in your PATH environment variable? If you monitor
MaestroAPITestRunner under Process Monitor, does it show trying to load dlls
from places other that the test directory?
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-getting-LocalNative-and-MapGuide-3-1-to-work-with-MaestroAPI-6-tp5287977p5288026.html
