[mapguide-users] Problem with MobileViewer and SSL (https)
Hans Milling
hm at geograf.dk
Fri Apr 7 00:29:03 PDT 2017
If your main page is running HTTPS, you need to load scripts etc. from HTTPS
also. Lucky you the virtualearth.net supports HTTPS too. Somewhere there is
a reference to the virtualearth script. just edit this to:
https://ecn.dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.2&mkt=en-us
That should work.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-MobileViewer-and-SSL-https-tp5316241p5316251.html
