[mapguide-users] Ajax viewer, URL in Properties Pane
RenoSun
renolionheart at gmail.com
Tue Feb 7 09:04:19 PST 2017
Hi Gom,
I am using nvarchar(255) as the data type of my HTML hyperlink.
Here is the HTML hyperlink field looks like on our SQL Server 2008 R2:
<http://server/rest/data/PropertyReport/1003.html>
<http://server/myrest/images/Doc.png> Property Report
Also, maybe use target="_blank" in your hyperlink like mine, so the user can
see your PDF in the new window.
However, you can choose just store simple URL such as
"http://server/rest/data/PropertyReport/1003.html", but you will have to add
codes in propertyctrl.templ.
Check if a Javascript string is a url
<http://stackoverflow.com/questions/5717093/check-if-a-javascript-string-is-a-url>
function ValidURL(str) {
var pattern = new RegExp('^(https?:\/\/)?'+ // protocol
'((([a-z\d]([a-z\d-]*[a-z\d])*)\.)+[a-z]{2,}|'+ // domain name
'((\d{1,3}\.){3}\d{1,3}))'+ // OR ip (v4) address
'(\:\d+)?(\/[-a-z\d%_.~+]*)*'+ // port and path
'(\?[;&a-z\d%_.~+=-]*)?'+ // query string
'(\#[-a-z\d_]*)?$','i'); // fragment locater
if(!pattern.test(str)) {
alert("Please enter a valid URL.");
return false;
} else {
return true;
function generateHTMLLink(linkName,href)
return " " + linkName+ " <\""> ";
Please see the example code here...
propertyctrl.txt
<http://osgeo-org.1560.x6.nabble.com/file/n5306766/propertyctrl.txt>
Cheers,
Reno
View this message in context: http://osgeo-org.1560.x6.nabble.com/Ajax-viewer-URL-in-Properties-Pane-tp5306236p5306766.html
