[mapguide-users] FW: Change Layer Visibility - Mapguide With Openlayers3
Greg Neff gbneff at cid.utah.gov
Fri Feb 10 14:35:05 PST 2017
I found my problem.  It was here:
map.Save(resService); should be map.Save();
Updating the OpenLayers mapguide layer accomplished like this:
var params = mgLayer.getSource().getParams();
params.t = new Date().getMilliseconds();
mgLayer.getSource().updateParams(params);
Thanks,
Gregory B. Neff
District Engineer
Cottonwood Improvement District
8620 Highland Drive
Sandy, Utah 84093
(801) 943-7671
*Sent:* Friday, February 10, 2017 11:34 AM
*To:* 'mapguide-users at lists.osgeo.org' <mapguide-users at lists.osgeo.org>
*Subject:* Change Layer Visibility - Mapguide With Openlayers3
OpenLayers v3.18
Mapguide 3.1 64 bit
IIs – Windows 10
Is it possible to change the visibility of a Mapguide  map layer using the
Mapguide api and then have the change reflected in the openlayers viewer
where the Mapguide map is a layer?
I have tried the following code below and seem to be able to get the layer
visibility and set the visibility, but I don’t think the changes are being
saved to the “runtime” or session map. (btw: When I couldn’t make it work
with OpenLayers, I tried it in the AJAX viewer with an invoke url running
in the task pane and that is the code shown.)
Thanks,
Gregory B. Neff
District Engineer
8620 Highland Drive
Sandy, Utah 84093
(801) 943-7671
<%@ Import Namespace="OSGeo.MapGuide" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "
http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title> Changing Layer Visibility</title>
    <script type="text/javascript">
        function RefreshMap() {
            parent.parent.Refresh();
    </script>
</head>
<body onload="javascript:RefreshMap()">
        String sessionId = Request.Form.Get("SESSION");
        //make sure to pass these values
        //String mapguideMapResource = Request.Form.Get("mapguideMapName");
        String mapguideMapResource = "Cid_Map";
        //String mapguideLayer =
Request.Form.Get("mapguideCleanedLinesLayer");
        String mapguideLayer = "linesCleaned2017";
        String realPath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
        realPath = realPath.Replace(@"Cid_Map\", "");
        String configPath = realPath + "webconfig.ini";
        MapGuideApi.MgInitializeWebTier(configPath);
        MgUserInformation userInfo = new MgUserInformation(sessionId);
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgResourceService resService = (MgResourceService
)siteConnection.CreateService(MgServiceType.ResourceService);
        MgMap map = new MgMap(siteConnection);
        map.Open(resService, mapguideMapResource);
        MgLayerCollection layers = map.GetLayers();
        //MgLayerBase layerClean2017 = layers.GetItem(mapguideLayer);
        MgLayer layer = (MgLayer)layers.GetItem(mapguideLayer);
        if (layer.GetVisible())
            layer.SetVisible(false);
        else
            layer.SetVisible(true);
        layer.ForceRefresh();
        Response.Write(sessionId + "</br>");
        Response.Write("Map Name: " + map.GetName() + "</br>");
        Response.Write(layer.GetName() + " " + layer.GetVisible());
</body>
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170210/4bf1091e/attachment.html>
