[mapguide-users] MapGuide Open Source v3.1 - LDAP Fails to Load
Jackie Ng jumpinjackie at gmail.com
Tue Feb 14 16:05:04 PST 2017
To spare you a long story about how Windows locates dlls to load, the path
C:\Program Files\OSGeo\MapGuide\Web\Php is not a known path to look for
dependent dlls to load under a default MapGuide/Apache configuration.
Thus if there are possibly dependent dlls in this path that certain PHP
extensions need, they have to be explicitly loaded through LoadFile
directives in httpd.conf
That's what the preceding LoadFile directives are there for, to make sure
all the dependencies of the PHP MapGuide extension (php_MapGuideApi) are
satisfied so that it works out of the box.
Your Oracle and SQL Server examples are I assume because said dlls sit in
$INSTALL\Server\Fdo, which MapGuide already is configured to know to look
for dlls in that location.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-v3-1-LDAP-Fails-to-Load-tp5307623p5307956.html
