[mapguide-users] MapGuide Open Source v3.1 - LDAP Fails to Load
Lisa Weber
lisaw at precisionmanagementsolutions.com.au
Tue Feb 14 09:03:54 PST 2017
Thanks Jackie. That did the trick. I was unaware that the alterations to httpd.conf were required, as I used the same approach to the LDAP dll as I have with Oracle and SQL Server dlls, which to date have not required an entry into httpd.conf.
Thanks again,
Lisa
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, 13 February 2017 9:19 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] MapGuide Open Source v3.1 - LDAP Fails to Load
MGOS 3.1 comes bundled with PHP 5.6.23, so you've copied in the wrong dlls
At this point, I think you're better off reinstalling 3.1 and removing whatever dlls you put under System32/SysWOW64
Once you have a clean slate 3.1 install, you want to edit $YOURMAPGUIDEINSTALL\Web\Apache24\conf\httpd.conf and add the following lines after the first batch of LoadFile statements
# Required for php_ldap extension to work LoadFile "C:/Program Files/OSGeo/MapGuide/Web/Php/libeay32.dll"
LoadFile "C:/Program Files/OSGeo/MapGuide/Web/Php/ssleay32.dll"
LoadFile "C:/Program Files/OSGeo/MapGuide/Web/Php/libsasl.dll"
These 3 dlls are what php_ldap.dll depends on and putting those lines in httpd.conf will make sure these dlls are pre-loaded as Apache httpd starts up.
Then if you open a URL to a PHP script whose content is:
<?php
phpinfo();
You should then see the ldap extension being listed as loaded and enabled.
Hope that helps.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-v3-1-LDAP-Fails-to-Load-tp5307623p5307694.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
