[mapguide-users] MapGuide Open Source v3.1 - LDAP Fails to Load
    Jackie Ng
    jumpinjackie at gmail.com
    Mon Feb 13 03:18:48 PST 2017
MGOS 3.1 comes bundled with PHP 5.6.23, so you've copied in the wrong dlls
At this point, I think you're better off reinstalling 3.1 and removing
whatever dlls you put under System32/SysWOW64
Once you have a clean slate 3.1 install, you want to edit
$YOURMAPGUIDEINSTALL\Web\Apache24\conf\httpd.conf and add the following
lines after the first batch of LoadFile statements
# Required for php_ldap extension to work
LoadFile "C:/Program Files/OSGeo/MapGuide/Web/Php/libeay32.dll"
LoadFile "C:/Program Files/OSGeo/MapGuide/Web/Php/ssleay32.dll"
LoadFile "C:/Program Files/OSGeo/MapGuide/Web/Php/libsasl.dll"
These 3 dlls are what php_ldap.dll depends on and putting those lines in
httpd.conf will make sure these dlls are pre-loaded as Apache httpd starts
up.
Then if you open a URL to a PHP script whose content is:
<?php
phpinfo();
You should then see the ldap extension being listed as loaded and enabled.
Hope that helps.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Open-Source-v3-1-LDAP-Fails-to-Load-tp5307623p5307694.html
