[mapguide-users] Synchronize multiple mapguide instances
Jackie Ng
jumpinjackie at gmail.com
Thu Feb 23 16:15:25 PST 2017
This is a untapped space that I've only dipped my feet in, but you should
look at putting MapGuide inside docker containers.
You can then script out the install/data/configuration set up in the
Dockerfiles. You can leverage docker shared volumes to put shared spatial
data files and reference them from MapGuide containers with external
aliases.
With Windows 10 / Server 2016, you can have windows docker containers as
well.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Synchronize-multiple-mapguide-instances-tp5309286p5309337.html
