[mapguide-users] 30 seconds delay after creating +/-100 CreateRuntimeMap calls
Jackie Ng jumpinjackie at gmail.com
Mon Feb 27 14:15:40 PST 2017
CREATERUNTIMEMAP itself will also create a session for you if you do not pass
a session id to it.
Do you pass the session ID to the CREATERUNTIMEMAP call? If not, that's 2
sessions created for every time you are starting up your viewer. If you are
doing 100 calls before seeing a 30s delay, assuming you didn't pass session
id to CREATERUNTIMEMAP, then that's (100 * 2 = 200 sessions created) and you
might have just hit the default value of SessionRepositoriesLimit in
serverconfig.ini
If you haven't bumped up this value, you probably should.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/30-seconds-delay-after-creating-100-CreateRuntimeMap-calls-tp5309691p5309742.html
