[mapguide-users] mapguide-react-layout 0.7 released
Jackie Ng jumpinjackie at gmail.com
Wed Jan 4 15:54:29 PST 2017
Re: nested layergroups
Most likely a bug, probably because I forget that a layergroup itself can
have child layergroups
Re: maptip
I'm sure this is normal behaviour that the tooltip query stops at the first
feature of a matching tooltip-enabled layer and returns tooltip data for
that feature.
Good to hear another data point about the good performance. I suspect the
legend was the bottleneck for older viewers on heavy maps due to the large
amount of DOM nodes (to represent layers/groups/rules) needed to be manually
created/shuffled around.
React and its highly-performant virtual DOM makes this a non-issue, which is
why the legend in mapguide-react-layout is much more snappy.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-react-layout-0-7-released-tp5301769p5302056.html
