[mapguide-users] react-layout: Hooking to events in the AJAX viewer (OnSelectionChanged)
Jackie Ng
jumpinjackie at gmail.com
Wed Mar 1 00:09:52 PST 2017
I thought about this some more.
Since your aim is to ultimately be showing some kind of URL the task pane
(or new window, or frame) in response to a selection, and my aim is for this
viewer to be as much configuration-driven as it possibly can be (I want
custom coding to be a last resort solution where possible), I think the
easiest solution would be to add some kind of mount property that allows
certain InvokeURL commands to be automatically run on a selection change.
InvokeURL commands already have layer/selection filters and parameter
support. The only thing is such commands require manually clicking said
command from a referencing menu or toolbar after a selection has been made.
To put this another way, can you achieve what you're after currently with a
manually clicked InvokeURL command?
If so, I can easily make the manual part automatic.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/react-layout-Hooking-to-events-in-the-AJAX-viewer-OnSelectionChanged-tp5309934p5310066.html
