[mapguide-users] react-layout: Hooking to events in the AJAX viewer (OnSelectionChanged)
Matze schramm at kom21.de
Wed Mar 1 03:55:07 PST 2017
In former times I did the invokeURL as you mentioned. Click/select a feature,
press a button with the invokeURL and the result ended up in the taskpane.
In this little  example <https://geodaten.landkreis-fuerth.de/osgeodemo/>
(sorry, it's in german), you can see a workaround with the normal Ajax
Viewer. The user clicks on a feature in the map and than the result will
show up in a separate tab in the taskpane, without reload the whole
taskpane.
For that, it would be nice to configure the mount function with invokeURL
and/or a custum handler/script.
View this message in context: http://osgeo-org.1560.x6.nabble.com/react-layout-Hooking-to-events-in-the-AJAX-viewer-OnSelectionChanged-tp5309934p5310108.html
