[mapguide-users] Spatial Contexts
Gord McKenzie
gord.mckenzie at canam.com
Fri Mar 3 10:08:38 PST 2017
I have a PostGIS database that has a good number of tables in it. The Spatial Contexts has always showed all the coordinate systems of the various tables. I added a table recently, that uses a 10TM coordinate system, EPSG3400. The feature source does not seem to want to list this coordinate system.
I have edited the XML and added any entry manually and it shows up in the list. However, when I Preview the feature source and look at its geometry properties it has choosen the Context named sc_3, which is not the correct context.
Any ideas as to why it doesn't detect the correct coordinate system or how I can force it to use my manually added context?
(The data source in PostGIS definitely shows the right Coordinate System and I can use a program like global mapper to see that it is correctly interpreted.
Thanks.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170303/788cdb6e/attachment.html>
