[mapguide-users] Creating tiled map from untiled
Hans Milling
hm at geograf.dk
Mon Mar 6 01:54:03 PST 2017
In Maestro you can convert ordinary groups to base layers groups with a
single click of a button (the one to the far right in the Layers section of
your map.
If your layers are not in a group, put them in a group and click the button.
Next go to Base Layer Groups and add som Finite Display Scales for the
tiled map.
Finally use MGCooker (the button with the globe) to generate the tiles.
Best regards
Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Creating-tiled-map-from-untiled-tp5310792p5310875.html
