[mapguide-users] Help with Spatial Contexts
gom
gord.mckenzie at canam.com
Thu Mar 9 07:23:39 PST 2017
Thanks for the thorough answer. That does match what my understanding has
been. My question arose because I added a data table to PostGIS recently.
In the Maestro Preview of that data source, the table showed sc_3 as the
spatial context of the table. The layer showed sc_2 as its selected spatial
context. SC_3 was a 10TM zone and sc_2 was a UTM11 zone. The data shift,
when adding the layer to the map, was equal to the difference in the two UTM
zone definitions.
I tried to refresh the spatial contexts list.
I dropped and recreated the layer.
The problem never went away.
I have not tried to re-create the data source as I have an application with
quite a few layers using this data source. I have quite a lot of tables in
the database as well as about 9 -10 different spatial contexts. Tables have
been added and dropped over time. Maybe I need to vacuum the database or do
some other maintenance to clean it up.
I will try to recreate the data source to see if there is anything related
to that.
Thanks again.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-with-Spatial-Contexts-tp5310988p5311605.html
