[mapguide-users] Help with Spatial Contexts
Jackie Ng
jumpinjackie at gmail.com
Tue Mar 7 02:47:26 PST 2017
The logical model goes like this:
A Feature Source
- Has 1..n spatial contexts
- Each spatial context is uniquely named
- Has 1..n feature classes
- Each feature class has a designated logical geometry property
- That geometry property has a spatial context association (to an
existing name spatial context in the Feature Source)
Thus a layer's spatial context is the spatial context of the chosen geometry
property of the feature class it is referencing. You don't assign a spatial
context to a layer, you assign a feature class/geometry and the layer picks
up the referenced spatial context from that.
Now seeing you are talking about PostGIS in your other un-answered post, let
me try to have a reasonable guess at how the FDO provider translates the
PostGIS database into this logical model
A Feature Source (A connection to a PostGIS database)
- [PostGIS Provider] It most likely infers this list from the
spatial_ref_sys and geometry_columns metadata tables
- [PostGIS Provider] Any table that has a geometry/geography column
- [PostGIS Provider] It probably either takes the first
geometry/geography column or whatever is specified in geometry_columns
- That geometry property has a spatial context of the chosen geometry
- [PostGIS Provider] It probably either looks up geometry_columns or
ST_SRID()'s the geometry/geography column so it knows what spatial_ref_sys
table entry you are referring to.
Now if you're wondering what is the purpose of a spatial context, it is
primarily to determine the coordinate system of the originating layer.
MapGuide uses spatial context information to determine if layers need
on-the-fly feature re-projection when rendering maps.
Hope that helps.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-with-Spatial-Contexts-tp5310988p5311169.html
