[mapguide-users] Synchronize multiple mapguide instances
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Thu Mar 16 01:32:31 PDT 2017
Yes, each node is server/web tier pair.
This was the reason for syncing repository between nodes.
Sticky session in HaProxy need to be set, because all requests from one user
need to be redirected to the same backend node (Mapguide Session).
HaProxy has also the ability of healt check if one of node fails.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Synchronize-multiple-mapguide-instances-tp5309286p5312637.html
