[mapguide-users] Synchronize multiple mapguide instances
Mark Bratcher mbratcher at atlasgeodata.com
Thu Mar 16 06:30:04 PDT 2017
Srecko,
Thanks for sharing I figured that would be possible but I haven't dug into
the API, that may be just the thing I need.
Would you mind sharing a bit of your implementation? I understand if you
don't.
I'm also running multiple instances behind HaProxy with basically the same
setup. I have about 70 top level repository items spread across 6 machines,
each resource is on a minimum of two machines and every machine is
identical so I can move resource between machines.
On Thu, Mar 16, 2017 at 3:32 AM, Srecko Lipovsek <srecko.lipovsek at kaliopa.si
> wrote:
> Yes, each node is server/web tier pair.
> This was the reason for syncing repository between nodes.
> Sticky session in HaProxy need to be set, because all requests from one
> user
> need to be redirected to the same backend node (Mapguide Session).
> HaProxy has also the ability of healt check if one of node fails.
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/Synchronize-multiple-mapguide-instances-tp5309286p5312637.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapguide-users
*Mark Bratcher*
*Atlas Geographic Data, Inc.*
*voice: 910.256.9892*
*cell:  910.547.7105*
*www.atlasgeodata.com <http://www.atlasgeodata.com>*
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager
admin at atlasgeodata.com.
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170316/c1e998d8/attachment.html>
