[mapguide-users] How to connect oracle by using Mapguide Maestro
gom
gord.mckenzie at canam.com
Wed May 3 12:43:16 PDT 2017
You should download and install the Oracle Instant client from Oracle's
website. You will need to create a user account with Oracle. There are 32
and 64 bit versions of the client as well as for different versions of
Oracle. If the oci.dll folder is on your path it should work but you may
wish to copy the supporting Oracle dlls to your fdo folder.
Hope that points you in the right direction.
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-connect-oracle-by-using-Mapguide-Maestro-tp4195265p5319320.html
