[mapguide-users] How to connect oracle by using Mapguide Maestro
Gord McKenzie
gord.mckenzie at canam.com
Wed May 3 11:46:49 PDT 2017
You should download and install the Oracle Instant client from Oracle's website. You will need to create a user account with Oracle. There are 32 and 64 bit versions of the client as well as for different versions of Oracle. If the oci.dll folder is on your path it should work but like a lot of these things you may have to experiment a little to get things to work.
Hope that points you in the right direction.
-----Original Message-----
From: mapguide-users [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of open_saucer
Sent: Wednesday, May 03, 2017 11:45 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] How to connect oracle by using Mapguide Maestro
Thanks Jackie,
What do you mean OCI.dll? when I extract the tar.gz I only get three dlls.
Is there some other files or dlls that I have to have?
<http://osgeo-org.1560.x6.nabble.com/file/n5319309/dlls.png>
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-connect-oracle-by-using-Mapguide-Maestro-tp4195265p5319309.html
mapguide-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapguide-users
