[mapguide-users] How to connect oracle by using Mapguide Maestro
open_saucer t_mcgill at outlook.com
Mon May 15 18:12:37 PDT 2017
Thanks Bernhard,
you are right, it was with the 32 bit vs 64 bit Oracle client.
I originally installed oracle 32 bit client because I thought that's what I
needed due to a Oracle 32 bit database I had installed on my db server.  It
is now working because of the installation of a 64 bit Oracle Client on the
MG server instead of 32.
Several of the screenshots was with different version of MG installed (2.6,
then 3.0), because I thought I'd test it out on different version of MG to
see if its working.  It turns out to be the Oracle Client bit issue instead.
Sorry for the confusion!
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-connect-oracle-by-using-Mapguide-Maestro-tp4195265p5320611.html
