[mapguide-users] Mapguide 3.0 layer permissions
Liglio liglio at pobox.com
Mon May 22 19:03:12 PDT 2017
In maestro in map configuration you set layers initially not visible. When
you will show the map you set the layers that you want to be visible, based
on the user permissions.
Do you know how to set a layer visible in your code ?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-3-0-layer-permissions-tp5320761p5321368.html
