[mapguide-users] Mapguide 3.0 layer permissions
Kajar kajar.kuldsepp at gmail.com
Tue May 23 09:32:11 PDT 2017
I just thought this layer rights management is done using only maestro or
AIMS Studio.
But as I understood there is need to go to code level to set layers visible
or not when map loads.
Actually I dont know how to set layers visibility in code based user rights
I just use predefined web templates without any additional coding.
If you can point me a right way how to add  this layers visibility in code,
I'll be really thankful.
Does this coding means changing template index.html?
Kajar
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapguide-3-0-layer-permissions-tp5320761p5321515.html
